Results 1 to 8 of 8
    Default Ignition Switch Question?
    My ignition cylinder (part where the key goes in) has been real loose and so I bought a new one to install however when I pulled of the black plastic cover to get to it the bottom of the ignition switch that bolts to the steering column fell out and the white plastic part is broken in two. First question is would that make the ignition cylinder loose and therefore not need to change it and second question how in the world would that thing break like that. Has anyone had it break before? I guess I have a third question would this be the reason I'm not getting power to my fuel pump?
    BTW it is on my 84 GT Turbo.
    65 Mustang
    77 Mustang
    84 GT Turbo
    85 Mustang Convertible
    86 Mustang LX
    Apr 2008
    Waikoloa , Hawaii
    If the switch is seperated, which is common, get a new ford piece. If the bolts just vibrated loose, that could be your problem, I THINK They ground through the column. It can cause fuel pump issues at the ignition switch.
    1986 CHP SSP Coupe
    The plastic has come off the metal is that what you are talking about separating?
    65 Mustang
    77 Mustang
    84 GT Turbo
    86 Mustang LX
    I have not personally had this problem but my understanding is that it is extremely common for the plastic and metal parts to come apart.
    1986 Mustang LX convertible 3.8L V6 C4 auto
    1975 Ford Gran Torino 351W C4
    1995 Ford F150 XL 5.0L 4R70W
    2015 Mustang 3.7L V6/auto
    Apr 2008
    Waikoloa , Hawaii
    Yeah, get a new Ford piece, not parts store junk if possible.
    1986 CHP SSP Coupe
    Thanks guys Will this also cause my key to be real loose?
    65 Mustang
    77 Mustang
    84 GT Turbo
    86 Mustang LX
    FEP Super Member 86capriASC's Avatar
    Jun 2008
    Edgerton,WI
    Put a new ignition switch and see if it makes a difference. If so take the new tumbler back.
    1986 ASCMclaren #108
    stock short block, Victor EFI, 75mm TB, 3.08's, Borla cat-back, slot style MAF conversion, Gt-40p heads, TFS1 cam, 80lb injectors, 69mm turbo, Moates Quaterhorse, E85. 501/584 @ the rear wheels
    Quote Originally Posted by 86capriASC View Post
    Yah that's what I was thinking. Thanks guys
    65 Mustang
    77 Mustang
    84 GT Turbo
    86 Mustang LX
