    FEP Super Member dburdyshaw's Avatar
    Jul 2005
    Florida (sometimes Arkansas)
    Default Why Does Clearcoat Fail / Peel?
    The research that I'm doing on this question isn't really answering it, so does anyone have an knowledge or experience with this question.
    I found this information on Wikiautos, but it only skims the surface.
    Causes of Car Paint Peeling
    There are normally three layers of coatings on a modern automobile: primer, paint, and the clear coat. The primer acts as a base layer for the paint, assisting with adhesion, provides a predictable surface for coating, and provides additional protection for the underlying metal. The paint is the color coat. The clear coat provides a hard "shell" that protects the paint from oxidization, minor scratches, and increases the longevity of the aesthetic benefits of the colored paint. Car paint peeling (delamination) occurs when one or more of these layers lose adhesion with the surface under it. Primer may lose adhesion to the bare metal, paint may lose adhesion to the primer, and the clear coat can lose adhesion to the paint. When this happens, large sections or flakes of paint can slough off the vehicle.
    There are two primary causes for car paint peeling. The first, and most often associated with large-scale paint delamination, is the improper preparation of the painted surface. All three major domestic manufacturers have had paint problems in the late-1980's through the mid-1990's due to changes in painting processes which resulted in the failure of either the primer, paint, or clear coat.
    The second most common cause of paint delamination happens when the seal of the clear coat, paint, or primer get compromised by a chip or scratch. Once the barrier has been compromised, moisture and other contaminants can begin working their way under the coatings and create a starting point for delamination. There are reported instances where a small chip in the clear coat has caused catastrophic adhesion loss to the clear coat when the vehicle was pressure washed. The pressurized water gets under the coating and quite literally blows off hard, brittle shell of the clear coat. However, this scale of clear coat failure due to a chip is rare, and is indicative of other quality issues with the paint.
    Factory Paint Failure
    In 1995, General Motors offered a repaint under warranty for any vehicle 5 years or newer experiencing severe paint delamination, regardless of mileage. The problem was so wide spread that there was a Dateline special covering the problem in 1997. Today, delamination of factory applied finishes is rare. Those with vehicles from the late-1980's to mid-1990's that are now experiencing paint delamination due to the processes used at the factory are usually without recourse. In some instances, owners have resorted to small claims court in an attempt to get their vehicle repainted on a pro-rated basis. Given that some of these vehicles are now approaching 20 years of age, the pro-rated value of the paint reimbursement is negligible, at best
    13 Dodge Dart
    09 Shadow Sabre
    08 Caliber
    05 Aztek
    02 Avalanche
    02 Thunderbird
    01 Cadillac ETC
    98 Explorer
    96 Suzuki X-90
    89 Fleetwood
    89 Continental
    88 Town Car
    86 Silverado
    84 Fiero
    83 Town Car
    82 LN7
    82 EXP
    80 Mustang
    65 Continental
    62 Galaxie 500
    54 Packard
    Stock never goes out of style.
    Jul 2010
    Houston (Clear Lake), Texas
    There are different qualities of clear coat out there...and as you can imagine, you get what you pay for. Also, you should have 3-4 coats of clear over the paint to keep it intact. A paint job all comes down to weather, chemicals mixed correctly, and the person spraying the car.
    HAD
    HAVE
    FEP Super Member 83GTRAG's Avatar
    York, PA
    +1 and a doubler on the weather,,, keep that moisture out.
    Rob
    current cars:
    83 GT Convertible
    83 Project GT T-Top Coupe
    84 GT T-Top Hatch
    86 GT Hatch low mile car
    00 V-6 Convertible
    all white cars!
    Jul 2005
    Though my question was, initially, concerning new cars ---- what makes it fail on cars that are about 10-15 years old?
    Are they just aging -- or is it something more complicated?
    Jul 2010
    Most cars from the factory have 2 clear coats at best...this along with cheaper materials equal not holding up over time, especially if exposed to abnormal conditions. A paint job done by a shop will typically put 3-4 coats of a good quality clear coat...this along with good weather and know how equals a paint job that will last a long time. 10-15 years for a factory paint job is a fair amount of time to expect it to last in normal conditions.
    HAD
    HAVE
