Would it be better to source some aftermarket axles and gears for the factory 7.5 or find an 8.8 from a junkyard?
I read someone's thread on swapping rear ends in an SVO and they had to modify some brackets, change break lines and parts and ended up not being able to use the factory quad shocks. I would rather not have to do any of that if there is a source for stronger than factory axles and carrier out there somewhere.
If the swap were easier I would probably go that route, but even then it's not a built rear end and will most likely be out of an unknow mileage junk yard car and need new or stronger parts, at least eventually.
So does anyone know of a source for stronger parts for the 7.5"?
