Yesterday while i was fixing a no crank problem with my svo, i started to back the car out of the driveway and smoke started coming from under the dash I shut it off immediately. Anytime i turned the key on it would start smoking.
after freaking out and pulling the cluster and trying to figure out where it was coming from i decided to pull the pwr. window/etc fuse and now no smoke. This car doesnt have pwr. windows and the ETC has been deleted. It has a J3chip.
The best i can tell the PO had ran a jumper wire from that fuse box location to the foglight switch on the dash to run the cooling fan on a switch.
Is this why it caused the electrical problem ? How else can i wire up the cooling fan with the switch SAFELY without causing anymore electrical problems ?
