Results 1 to 8 of 8
    FEP Power Member blue beast's Avatar
    Jul 2005
    Green Bay, Wisconsin, United States
    Default Radiator support repair
    Is there a place that sells replacement supports for the pre 83 cars? My 80 notch is completly rusted out in the middle section on the bottom (sorry no pics) Each side is still fairly solid, so would the best way to repair this just weld in a section between the two?
    82 Mustang GT
    T5, 8.8
    Holley 650
    Performer 289
    BBK Shorties & H-Pipe
    Waiting for a Foureyed of the month vote!!!
    Current Project: 1980 Project Green Machine
    1999 Ford Taurus SHO DD
    FEP Member Ratrod62's Avatar
    Aug 2009
    Montreal, Quebec,Canada
    I would consider going to a scrap yard and looking for that area in one if it can be found. Most of these places should be able to torch out more than you need and you trim to fit. As an fyi you should weld in some sort of a support prior to removing the center section to ensure it doesn't move while getting the rusty part out.
    Maybe put a request for the part on the WTB section.
    Current rides
    86 Capri RS (bone stock)
    86 Mustang GT (with mods)
    83 Crimson Cat
    89 5.0 Notch
    Past rides
    80 Cobra
    81 LX
    78 King Cobra
    67 GT390
    85 Capri RS
    85 GT Stang
    Jul 2005
    yea local yards are kinda outta the question, lets put it this way, i get really excited to see any fox around by me, and when i saw these 2 at a yard i bought both immediatly. Too late for the brace weld, as the middle was gone...lol.
    82 Mustang GT
    T5, 8.8
    Holley 650
    Performer 289
    FEP Power Member racerxmd's Avatar
    Sep 2007
    Rockville,MD.
    Team Z has a weld in that will work just find!
    Jul 2005
    team z? do you have a link?
    82 Mustang GT
    T5, 8.8
    Holley 650
    Performer 289
    FEP Senior Member flyin5-o's Avatar
    Sep 2006
    Fond du Lac,Wisconsin
    Quote Originally Posted by blue beast View Post
    PM me if you are interested in a tubular lower section.
    I would suggest just splicing in a stock or aftermarket lower section. when I crunched mine I could only fine them with good upper portion, or good lower portion but not both. I needed the side walls to the shock towers thus I bought one with a perfect upper then went to pull and save and found a nearly perfect lower and spliced them together.
    Good luck!
    Kenny
    Looks nice, but kinda pricy. I would be more inclined to make my own.
    http://www.teamzmotorsports.net/Must...tzm-fox-rs.htm
    Jess
    Currently own;
    Previously owned;
