Hi just joined this forum. Mine is 180277, 5.0, manual, sunroof.
Welcome to FEP. Can you post pics of your door tag and buck tag, either here or in the decoding forum? Thanks.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
Hope this goes through.
I have added 180277 to the database and registry. Please take a look at the following options list and let me know if your car has them. I already know most options your car has by the codes on the door tag and buck tag. The following list are items that are not indicated on either. If you happen to take up the front or rear carpet, or remove the spare tire or interior quarter panels, you may also find a build sheet. Could you remove the buck tag and tell me what the four digit number is by the screw hole? Also, how many miles are on the odometer? Thanks.
- front license plate bracket
- interval windshield wipers (twist knob for timed delay + normal off/low/high)
- light convenience group (engine compartment, glove box light, and front ashtray light, hatchback area light and switch, headlamp-on warning buzzer, remote release fuel filler door)
- premium sound system ("AMP PULL" switch to left of radio and amplifier under center of dash pad)
- tilt steering wheel
- tinted glass (dark upper windshield, slight green or brown tint to side and rear glass)
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
The mileage is 88,924. The number by the screwhole on the buck tag has 3 digits, 028. The car has the premium sound system, interval wipers, a front plate bracket and tilt steering wheel. It doesn't have tinted windows or the light convenience package, but does have remote fuel door and trunk releases in the glovebox.
There four digits by the screw hole. The fourth digit is beneath the screw head. I updated the info in the database and registry. Thanks.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
181444 added
found on ebay in Canada
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
181126 added
found in ebay
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
Added 180534 (5.0L/T5 convertible) and 181454 (5.0L/AOD convertible)
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
Highest vin for a 20th is 1FABP27MXEF204789. Taken from a 20th aniv. registry from 1989...............
DSO is a Ford dealer designation code, the first 2 numbers or numbers/letters of the ordering Ford dealer. AX is axle code as there were 2 different ratio's offered. 2:73's or 3:08's I believe? TR is the transmission code.
