Results 1 to 25 of 48
    FEP Member 85.0's Avatar
    Aug 2007
    El Centro, Ca
    Default SN95 parts on a foureye
    I got a call from my uncle last night, he's taking an SN95 to the crusher this weekend. It's a 3.8 but not sure what year and what's wrong with it. I have access to take whatever I need off the car, for sure I'll be taking the rear end off and te spindles. What else do you all know of that can be used as an upgrade to a foxbody.
    Dec 2009
    Fort Collins, Colorado
    alternator. Check this thread for details; http://vb.foureyedpride.com/showthre...=3G+alternator
    The rear end is a 7.5", so the only items worth using are the brakes and axles.
    Depending on what year it is will determine how many parts are of value to a Fox chassis.
    A Fox Chassis stated the rear end is a 7.5 so it will bolt into a Fox, but not worth the swap if you already have a 8.8. All of the brakes, axles, etc. can be swapped to your 8.8.
    A 3.8 manual is most likely a T5 transmission. Again not what you want behind a 5.0, but they can be used with other engines with some modifications.
    The spindles and front brakes are a great addition to a Fox, but remember you should not use 96+ spindles on a Fox without an aftermarket K member. It will cause severe bumpsteer that is almost impossible to correct.
    Best of Luck!
    Trey
    Aug 2007
    El Centro, Ca
    you're right I forgot about the alternator!!
    Aug 2007
    El Centro, Ca
    I thought i't be an 8.8. I could still use the brakes off it.....
    should I grab the brake lines or are the stocks ok.
    FEP Super Member 86fiveoh's Avatar
    Jul 2008
    West chester PA
    Id get whatever is in good shape, interior, exterior, ect. Should be able to unload most of the stuff and make some 4I modding money
    Aug 2007
    El Centro, Ca
    if it was up to me I'd take the car home and part it there, but I already have a full driveway. I guess I'll take whatever fits in my Cherokee and get some funds for my 85 from that. so far on the list are
    tail lights
    rear end
    spindles
    brakes
    ball joints
    headlights
    alternator
    wheels
    FEP Power Member horsepowerjunkie's Avatar
    Jul 2009
    Juist outside Minot, ND
    I beleive the 3.8 T5 trans has the same gear ratios and torque ratings as the 86-89 WC 5.0 T5's. All that is needed is to change the input shaft to a fox body shaft!
    11 GT Black, A6,Steeda CAI, SCT X4, Circle D 4C
    89LX Blk Hatch,363 Dart,C4,T76BB,FAST EFI
    86 Black GT, 331 Dart, S-trim aftercooled, 4R70W
    82 Carpi RS, 306, T5, 8.8 4.10's.
    72 Demon 340 4-speed(one of 1667)
    73 Dart Sport 340, 410ci, Indy 230cnc+, bracket brawler
    01 Ram Quad Cab, 5.9L car hauler
    02 Grizzley 660
    03 Honda VTX 1800
    Aug 2007
    El Centro, Ca
    I don't know what tranny it has yet, hopefully it is a t5
    will the radiator off an sn95 work on a foxbody? I'll be grabbing the e-fan as well
    Dec 2009
    Front seats will also bolt into a fox body. And if they are power, it will be an aded bonus. The power seat tracks can even be adapted to your fox seats.
    edit: be sure to get as much of the harness as possible.
    Yank the airbags, and all the parts that go with them. You can get at least a little coin for those I would think.
    ** 89 LX 5.0 ** blower whine, better brakes, and faded paint
    Aug 2007
    El Centro, Ca
    will do. thanks
    FEP Super Member 86capriASC's Avatar
    Jun 2008
    Edgerton,WI
    Don't forget the axles if you take the brakes.
    1986 ASCMclaren #108
    stock short block, Victor EFI, 75mm TB, 3.08's, Borla cat-back, slot style MAF conversion, Gt-40p heads, TFS1 cam, 80lb injectors, 69mm turbo, Moates Quaterhorse, E85. 501/584 @ the rear wheels
    Aug 2007
    El Centro, Ca
    I'm thinking of grabbing the whole rear then parting it when home
    FEP Senior Member subsGT's Avatar
    Dec 2009
    Central Texas
    Quote Originally Posted by 85.0 View Post
    I would...plus there are a few parts I'm sure you can or will use
    Front Spindles complete with brakes are good swap candiates for a Fox.
    Aug 2007
    El Centro, Ca
    those are on the to-do list.
    what all is good from the brakes?
    FEP Senior Member ngl9766's Avatar
    Aug 2010
    Near Houston Tx.
    Im not sure but I believe the control arms are wider and have better geometry as well. Might want to look in that. Heck the k member might be worthy. Im not sure if it will bolt into our year models though.
    Aug 2007
    El Centro, Ca
    wont the control arms push the wheels forward?
    FEP Power Member 4wheeldevil's Avatar
    Mar 2009
    Fredericksburg, VA
    isnt he gonna need the master cylinder and proportioning valve
    02 F150 Lightning
    82 mustang gt
    FEP Power Member MAD MIKE's Avatar
    Jan 2009
    San Leandro, Ca.
    Quote Originally Posted by 4wheeldevil View Post
    The MC is too big at 1-1/16" and the SN95 prop valve will not correctly bias a Fox Chassis. If changing to rear disc brakes on a drum brake equipped car it is best to install you own prop valve and fine tune it.
    85.0 did you find out what year the SN95 is?
    -Michael
    '79 Fairmont 5dr 'car guy safe' MM Tech Tips StopTech Brake Bias StopTech White Papers
    Aug 2007
    El Centro, Ca
    I will go take some parts from it today and bring some pictures with me and specs
    so MC is no good for me
    Aug 2004
    California
    ABS car? If so, maybe all of that stuff.
    The longer sn95 a-arms widen the Fox chassis front track (not wheelbase) about 2.5" over stock. When used with the narrower pick-up k-member on 86 and earlier cars, this is a pretty good upgrade combined with sn95 spindles resulting in regained negative camber and a much better camber curve with minimal fender clearance issues; when used with the wider pick-up k-member found on later Fox chassis v8 cars, fender clearance issues are pretty severe.
    Aug 2007
    El Centro, Ca
    bad news
    this is what the car looked like
    and it was such a tight fit in the trailer to remove the spindles and brakes. I thought I would at least be able to salvage some parts but all the good stuff was gone.
    I was able to get this from it though (to the right)
