Results 1 to 9 of 9
    New User
    Sep 2010
    Ridgetown, Ontario, Canada
    Default 5.0 front engine assembly
    I recently acquired a stock '84 Mercury Capri RS. A previous owner had diassembled the front end of the engine removing the water pump, alternator and its mount, smog pump, and power steering pump. I figured out how to mount the water pump with help from this site.
    I need some help with where the other parts mount and with what kind of bolts. A clean picture of the front end of an assembled 5.0 carb engine would help or perhaps some reference to a manual where this can be found.
    Jul 2005
    Medicine Hat, Alberta,Canada
    Here you go. I used a ford racing kit to mout the powersteering bracket.
    New User
    Sep 2010
    That's excellent!!
    Thank you.
    Jun 2006
    Streetsboro, Ohio
    The pic is correct if you don't have AC.
    George
    84 Capri 5.0 B303 cam, shorty headers, Flowmasters, MM Caster Camber plates,
    Dec 2007
    Eastern MA
    Here are pics with and w/o AC (FMS AC eliminator kit). This is an 89 engine -not sure if front dress is same as your 84.
    MF: Shoot pool Fast Eddie.
    New User
    Sep 2010
    Thanks for the clear pictures! It does not have AC so these pictures are really helpful.
    Hope some of these help you out:
    '86 Capri 5.0, black with charcoal interior, 5 spd, fully restored, mildly modded.
    '86 Capri 5.0, white with black interior, C4, rotisserie restored, heavily modded.
    Wow, that's a beautiful engine!
    Holy **** that is sick!!!!!!
