Results 1 to 21 of 21
    Default 1980 mustang fuel tank
    what makes the 1980 mustang gas tank different from other years? because i have a 1980 that is full of old gas(1996) and was wondering if other years would work if they were modded.
    FEP Power Member Flowpro's Avatar
    Jul 2008
    Waterloo, Iowa
    Interesting, I did not know this. I was keeping a 79 gas tank as a spare for my 80 Cobra in case I needed one down the road. What makes them different?
    ** Kurt **
    Current:
    1980 Mustang Cobra
    Past:
    1966 Mustang Coupe (first car!)
    1971 Mustang Grande
    1979 Mustang Hatchback
    thats what i am trying to figure out.
    Jul 2008
    Waterloo, Iowa
    Quote Originally Posted by CanyonGT View Post
    Sorry, misread your first post.
    I just went out and compared the spare gas tank(1979) to the one on my car(1980) and can't find any differences. Inlets are the same diameter, the lines out are the same (same spot also), both have the vapor line on top (can't actually see mine but there is a line going up there).
    So I went to Oreillys parts store online and compared the two. Both came up with part number F82A. Then I dug a little further and searched for an 81 gas tank, early 81's (pre 4/1/81) are the same as 79 and 80 but later ones have the fuel lines on top with the vapor return line. See pic below.
    http://www.oreillyauto.com/site/c/de...2539&ppt=C0025
    These were for Mustangs with factory 302's and 255's.
    So to answer your question, looks like you need one from 79 to early 81. Otherwise you would need to modify your fuel lines to route them to the top of the tank instead of the lower front passenger side.
    ** Kurt **
    Current:
    1980 Mustang Cobra
    Past:
    1971 Mustang Grande
    Dec 2009
    St. louis MO
    I thought they were the same from 79-82??
    Keith formerly STLPONDS
    '79 V8 coupe in the works!
    FEP Power Member kj_80Cobra's Avatar
    Feb 2006
    Harrisonburg, VA
    And the 79-80 gas tanks are not being remanufactured by anyone. If you have a good one, you better hang on to it. The older gas tanks are smaller than the 81-93 tanks, 12 gallons vs. 15 gallons. You can fit the newer style in a 79-80 car with some work. I just finished the job. You have to change the tank strap mounting points and I had to beat in the edge of the tank in a few places to get it to fit up into the space between the spare tire well and the frame rail. I used the newer tank straps too.
    thanks this is good info. do you have any pics of where you had to change the strap mounting points?
    I was about to say 81+ were bigger.
    My 79 has the old style 'T' shaped strap end. Slides into the slotted strap connection on the under body, over the axle area.
    The bumper end of the straps are basically the same as the newer ones.
    The newer straps have bolt on provisions at both ends.
    It is the front most end that is different. Have not crossed the river to do the conversion yet.
    Gonna get a fuel tank repair shop to do it, since i have no plans to do any Smokey Y. or military aircraft style tank drops ever.
    Feb 2006
    Harrisonburg, VA
    Added the later style tank strap mount on the passenger side and made a new mount for the driver's side. Had to move mounting bolt locations on the other side of the strap too.
    Dec 2007
    Eastern MA
    Quote Originally Posted by kj_80Cobra View Post
    Not so:
    Spectra Premium is producing the F82A (12.5g/47L) tank for 79-81 Mustangs (before 4/81). Rockauto.com has it and Im sure any auto parts store could order it. They are not making the straps for it though so you need to reuse the originals.
    MF: Shoot pool Fast Eddie.
    Feb 2006
    Harrisonburg, VA
    I never found that in my searches. If you have good straps, then that is a better option than all the mods needed to fit the bigger tank even if you switch over to efi like I am doing.
    Default RockAuto Pricing
    Here is what the results from RockAuto show as pertaining to a 1980:
    FINELINE Part # FLF12B
    $98.79
    SPECTRA PREMIUM Part # F82A
    (Only 1 Remaining)
    - Stocked in outlying warehouse--shipping delayed up to 1 business day
    $184.79
    Check it out here:
    http://www.rockauto.com/catalog/x,ca...CTRA%2BPREMIUM
    ~Corey
    80 Cobra
    07 F150
    awesome info guys thanks for the great info. my straps are good. so i will have to decide to go with new or used now.
    Thats what i wanted to do. I have never seen pics of how the factory hardware looks on a 79 and 80. I did what a member suggested and used carriage bolts in the rear. The 86 tank fits like crap in my 79 capri. The early spare tire well seems bigger.
    1979 capri, a mess, 86 efi
    Jul 2005
    Medicine Hat, Alberta,Canada
    The 85+ tanks are different as well because of the dual exhaust
    Currently FOXLESS...unless you can find me a nice original notch or nice cobra for sale.
    1981 Tu-toned coupe, 3.3 inline six, auto, Clifford header dual exhaust(first car)...gone not forgotten
    1982 Red hatchback(fixed it with parts from first car)
    1993 White LX Notchback 5.0, Auto...Sold
    1983 Bittersweet Factory optioned 5.0, 5 Speed T-top Coupe....Sold it on Remembrance Day 2014
    1982 Black GT, Factory 4.2(255) V8, Auto with premium sound and cassette....Sold
    1986 LX 5.0 Coupe, AUTO, Premium Sound Cassette, Red interior, white exterior. Very original Only 64,000 kms...SOLD
    Feb 2006
    Harrisonburg, VA
    Quote Originally Posted by mutantcapri1979 View Post
    The well is bigger, that's why the 79-80 tanks were smaller. I had to bash in the top edge of my brand new 84+ EFI tank to get it to fit right.
    FEP Senior Member SVO4PWR2's Avatar
    Jun 2006
    Linden, NJ exit 136
    I have a question for the people that used newer style tanks "electric fuel pump & sending units on top" in 79 - 80 cars.
    Does the 79 - 80 sending unit bolt in & does the gauge work properly.
    thanks -RICH-
    84 CAPRI RS FOR SALE
    i'm a car junkie - i love junkie cars
    FEP Senior Member cipher's Avatar
    Aug 2006
    wilmington n.c.
    Quote Originally Posted by SVO4PWR2 View Post
    thanks -RICH-
    No they sending unit don't work. To use a later efi tank you need a sending unit from a efi 83 to 86. CFI,turbo,and sefi cars all have the correct sending unit. I used a efi tank from a 89 gt car with a sending unit from a wrecked svo in my wifes 80 turbo rs.
    Mike J.
    80 Capri RS turbo(svo in capri clothing)
    86 SVO
    "Doh, Why do my actions have consequences?"
    How bad did you have to beat in the EFI tank?
    1981 T-top coupe - FEP #28
    1990 GT - H/C/I
    2003 GT daily driver - bolt-ons 252hp/292tq rw
    Feb 2006
    Harrisonburg, VA
    On the left side where the foam insulation tape is.
