Page 2 of 10 FirstFirst 1234 ... LastLast
Results 26 to 50 of 228
Thread: My '80 Fairmont
  1. #26
    FEP Super Member dburdyshaw's Avatar
    Jul 2005
    Florida (sometimes Arkansas)
    That's a WOW car forsure.
  2. #27
    Jul 2009
    Chicago, south subs
    Thanks for the compliments. I finally got around to installing '87-up spindles/brakes and also new Motorsports A-arms. Made a big difference in NVH.
    Bought one of those 'inside' coil spring compressors, made it much easier, but had dis-assemble the compressor to get it out after installing the springs. Installing the A-arms was made easier by starting at the rearmost bushing and getting the bolt started. I then used a ratcheting strap tied from the ball joint to the radiator core support. With tension on the strap, I tapped the A-arm into place with a soft-face hammer. All-in-all, went pretty good, but eat your Wheaties for getting those A-arm bolts loose.
  3. #28
    FEP Power Member Forever's Avatar
    Nov 2009
    TEXAS BABY !!!
    WOW your car IS very clean!!! .. I wish I could get something this nice
    I'm holdin on your rope, got me 10 feet off the ground
  4. #29
    New User
    Apr 2009
    Chicago south suburbs
    Thats great your keeping that car clean,I know that car was nearly flawless.
  5. #30
    Jul 2009
    Chicago, south subs
    It's worth noting that if you're upgrading the struts(my spindles came with a good set of struts/shocks) you must re-use the 'onion head' strut bushings or get caster/camber plates. The hole in the top of the shock tower isn't large enough to get full camber adjustment if you use newer oem strut bushings.
  6. #31
    Dec 2007
    Eastern MA
    Im not sure I understand the fit issue you are/were having? I also installed the complete 87+ front suspension and brakes and did not have any issue with the FLCAs. But I also installed a 90 GT K-member. Did you keep your original K?
    Also I did not use my original onion heads. I used the late Mustang upper mounts and had no issue getting the caster/camber correct. There are some different styles of the later mount - I think 79-89 and 90+ but dont hold me to that. Anyway only one type will fit the early Fox cars as the hole pattern for the upper mount studs was changed.
    MF: Shoot pool Fast Eddie.
  7. #32
    Jul 2009
    Chicago, south subs
    The A-arm issue was just they were a little too snug to just put in place. I used the strap to keep tension on them while tapping into place. Yes I kept the stock k-member.
    I'm not sure what year the upper strut bushings were, they came with the spindle/brakes/struts that I bought used. I installed them and the inner edge of the hole in the top of the shock tower came into contact with the outside of the bushing, so I removed them and re-installed the onion-head bushing. Problem solved. Still need to get an alignment.
  8. #33
    I had that same exact problem with mine...and solved in the same manner.
    1982 Mustang GT 460/c-4
    1979 Mustang ghia coupe...original 2.3 turbo 4 speed barn find
    http://s316.photobucket.com/albums/m...zephyr%20pics/
  9. #34
    Jul 2009
    Chicago, south subs
    Took care of this a while back. According to the shop's computerized alignment rack, I was within specs with caster/camber and only needed to adjust toe in/out 3/16" on one side and 1/8" on the other side. The car tracks straight and ride is greatly improved with these new control arms. Very happy.
  10. #35
    What rack did you use and where did you get it from.
  11. #36
    Jul 2009
    Chicago, south subs
    Quote Originally Posted by josephstjohn View Post
    Steering rack?
  12. #37
    Yes which steering rack.
  13. #38
    Jul 2009
    Chicago, south subs
    quick ratio, got it at PepBoys. I ended up replacing everything, hoses/pump too. I don't recall the pump being anything more than a replacement part and I have had no problems at all.
  14. #39
    FEP Power Member cylhead8's Avatar
    Sep 2007
    .687 int. .679 exh solid roller in a 396 windsor Whatchu got?????
    Progress pics of relative note?
    ~ May those who love us love us. And those that don’t love us, May God turn their hearts. And if He doesn’t turn their hearts, May he turn their ankles, So we’ll know them by their limping. ~
    IRISH TOAST
  15. #40
    Jul 2009
    Chicago, south subs
    Quote Originally Posted by cylhead8 View Post
    Been working A LOT. I'll try to get some, but it's usually dark when I leave for work and dark when I get home .
  16. #41
    Jul 2009
    Chicago, south subs
    Been a while. I picked up an extra set of tail lights and decided to try the blacked out look. I'm not knocked out by it, but I don't dislike the look either.
    BEFORE:
    AFTER:
  17. #42
    I like the dark bezel around it but the lights need to stay bright.
  18. #43
    Dec 2007
    Eastern MA
    I like the BEFORE. Might work better with a darker colored car.
  19. #44
    Jul 2009
    Chicago, south subs
    Can't believe it's been over a year since updating this thread. Haven't done much to the car until recently though. I just swapped an 8.8/3.27/trak-lok in over the weekend. Surprised to find a 6.75/2.73 rear under there. I checked the backlash(OK) and re-shimmed the trak-lok, new fluid and new upper bushings(Ford Racing). I had planned to keep the brakes on the car and swap them onto the 8.8, but since it wasn't a 7.5, I kept the brakes that were on the 8.8 and just swapped the brake lines. All the fittings worked, no adapters needed. I installed a 21 tooth(purple) speedo gear. I also removed the shock brackets from the 8.8 and the shock mounting studs from the 6.75 bolted right up in the holes on the 8.8.
  20. #45
    Mine had that same funny little rear. Hearing about more and more of them! Sweet car, by the way!
  21. #46
    Jul 2009
    Chicago, south subs
    Thanks. The interior needs work. Seats and carpet.
  22. #47
    Jul 2009
    Chicago, south subs
    Can't believe another year has gone by. Haven't done much to the 'mont, but I just picked some new shoes for her. Got a good deal on a set of rikens from a guy on CL, but they need new skins.
  23. #48
    Jul 2009
    Chicago, south subs
    OK, I couldn't wait til spring to see what it will look like. Please excuse the dirt, it's been too cold to wash. I still need to get new tires for these rims.
    Before: Name:  015.jpg
    After: Name:  016.jpg
    I like it.
  24. #49
    nice. very upscale looking.
  25. #50
    Looks great!
