08-31-2022, 11:05 AM
#226
Trying again. Hole in the floor with a T5 shifter poking through, lol. I have new carpet. I'm not ready to install yet.
Edit: Picture option failed. Also tried cut & paste which resulted in about a thousand lines of garbled text.
10-29-2022, 05:59 PM
#227
I found some nice bucket seats out of a 2000 Mustang, so the bench seat is out. installed subframe connectors. Will be installing the new carpet this coming week.
11-01-2022, 04:41 PM
#228
A couple years ago I installed a set of gauges, volts, temp, oil pressure. The oil pressure gauge is mechanical and has that plastic 1/8" tubing which recently started leaking at the engine end of the line. I replaced that tubing today with 1/8" copper. Hopefully, it will last longer than the plastic.
- You may not post replies
- You may not edit your posts
Forum Rules
