The windows on my 85 decided to quit working and they dont go up anymore. Which fuse can I check to see if it is blown or does this sound like the window switch went out?
is both not working , they run off same fuse
Yea both windows are not rolling up. What fuse is it in the fuse box?
its fuse number 14, 20 amp
Keep in mind that you might have a bad switch. Try to use the passenger side switch to see if it rolls up that side. If so its not a fuse...
Does fuse 14 only give power to the windows or does it control other things like the horn? Both windows do not roll up with either switch.
